Re: Will a Farmall H pull a 4 bottom disk plow?
Posted by CNKS on May 08, 2008 at 18:10:46 from (216.144.104.128):
In Reply to: Will a Farmall H pull a 4 bottom disk plow? posted by C-152 on May 08, 2008 at 06:28:34:
NO. It will pull a three disk plow. In the 50's I spent many hours with an H and a semi-mounted H/M 150 3 disk "breaking plow". The lower draft of the disks makes the "2 plow" H a 3 plow. An M will pull four. This is not criticism of the posts below, but most of them have not seen the type plow you are referring to, on the other hand, in south Texas where I grew up, no one had seen a moldboard.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
