Re: Farmall M engine update: won't start again
Posted by John M on May 08, 2008 at 18:28:31 from (209.213.22.170):
In Reply to: Farmall M engine update: won't start again posted by 1 Dollar on May 08, 2008 at 15:03:56:
Lets see, when you first started it, no water in the cooling system, then you added water, blowing a mist out, wasnt this the one you had to do some work on the cylinder wall. Id try draining the water back out, and then try it again. if it starts then youll know your problem.
