Re: Carb leaking? farmall A
Posted by Smith in TN on May 08, 2008 at 19:32:39 from (209.173.38.24):
In Reply to: Carb leaking? farmall A posted by francoisc27 on May 08, 2008 at 18:58:57:
My first guess is that the float is stuck or in a bind and can not come up.
Also my experince has been that when I take something like that apart I usually need new gaskets, cause the old ones rarely seal back correctly.
A rebuild kit is usually around $20.00 and they are not hard to do. I would highly recommend one. You will need to find a number on the carb so you can get the right kit.
Originally it had a 6 volt generator, a lot of people convert them to 12 volt alternator.
Hope this helps. :)
