Re: Opinions on IHC 806 - hydrauluics?
Posted by the tractor vet on May 08, 2008 at 19:37:21 from (99.167.214.147):
In Reply to: Opinions on IHC 806 - hydrauluics? posted by ironandsteel on May 08, 2008 at 17:21:32:
There is noting wrong with the hyd's on a 806 if the pumps are in good shape . If she is stock then they should flow 12 gph at rated pto speed and 1750 lbs pressure , yes you can install a 17 gph pump and yes you can install a 2350 relief . There are three pumps in a 806 one for the pto one for the main hitch a remotes and one for the MCV that controls steering T/A brakes and lube to the oil cooler and to the rearend . There is nothing on a 806 that can not be fixed with money time and love.
