Re: Opinions on IHC 806 - hydrauluics?
Posted by Lee in Iowa on May 08, 2008 at 21:30:47 from (66.172.198.78):
In Reply to: Opinions on IHC 806 - hydrauluics? posted by ironandsteel on May 08, 2008 at 17:21:32:
I've got an 856 which has the same hydraulic system maybe higher relief valve pressure I don't know. It has 12000 hours on it and it will easily pick up a ton round bale on the loader that has smaller cylinders on it meant for a 4020 john deere that has higher operating hydraulic pressure. Lee
