Re: 450 Gas battery cable
Posted by Randy in NE on May 09, 2008 at 04:45:47 from (204.124.193.192):
In Reply to: 450 Gas battery cable posted by Chris NW Ind on May 08, 2008 at 21:23:15:
As somebody mentioned in a reply a couple of days ago, you want to keep it as short as possible and the heavier the gauge of the cable the better. As long as you have room to manuever the cable for connecting it then it is long enough. If you want orginality then order it from your local Case/IH dealer. Otherwise any auto parts store will work. For heavy duty ones check with a truck repair shop or welding cables with solder ends works good.
