Re: 12 volt generator for a farmall A
Posted by Keith-OR on May 09, 2008 at 09:34:01 from (207.200.116.7):
In Reply to: 12 volt generator for a farmall A posted by packer fan on May 09, 2008 at 07:16:01:
If the alternator was mounted right and painted it would not look ugly. Can be made to blend in.
This alternator on Shawn's SC I used the pulley off the generator. I had to drill the alternator shaft and tap for a bolt to hold on the pulley.
third party image
third party image
Keith & Shawn(Special Olympic Gold)
