Re: 450 transmission trouble
Posted by ihc49 on May 09, 2008 at 20:02:46 from (216.123.197.195):
In Reply to: 450 transmission trouble posted by BradV on May 09, 2008 at 19:21:37:
are you sure your not just stuck in 2 gears at once? unbolt your gearshift and pull it out. look and see if the notches in the shifter rails are lined up. if not take a small pry bar and line up the 3 rails in neutral,then install shifter and away you go.hopefully this is it.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
