Re: 450 transmission trouble
Posted by NEKS on May 09, 2008 at 21:10:39 from (204.183.215.78):
In Reply to: 450 transmission trouble posted by BradV on May 09, 2008 at 19:21:37:
I recommend using the gearshift lever to line up the forks. I shifted a M out of 4th gear to fast and the gear slipped in to 5th with the gearshift in netural. Got a nice crome bar out of the tool box to fix the problem and dropped it down into the transmission. Heard it balance on the bottom of the tranny case. You never seen a teenage boy let out on the clutch so slow waiting for that bar to get into a couple of gears. Never did.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
