Re: Farmall H with IH no 30 Loader
Posted by Chuck46 on May 09, 2008 at 21:14:24 from (64.136.27.230):
In Reply to: Farmall H with IH no 30 Loader posted by Andy Motteberg on May 09, 2008 at 20:54:58:
Andy, You do not need the extra resevoir, the cylinders on the loader are the resevoir. All you need to do is remove dipstick, put a pipe union on the belly pump fill pipe, then a short nipple, a reducing tee facing sideways, " by that I mean a tee which has one 3/4 port and two 1/2 ports" then nipples long enough to get out to the edge off gas tank, an elbow on each and then hoses to the ports to the front of the cylinders. Set the loader on the ground, fill resevoir and both cylinders with oil, close it all up and it is ready to go. Good luck, Chuck
