.....and before anyone jumps me with, "the compression test would show that", remember that the valves are CLOSED when the piston is on the upstroke, so unless the valve doesn't seal, you'll show good compression.
Its on the DOWN stroke, when the intake valves are open, that it may be literally sucking oil through the valve guides into the cylinder, resulting in a fouling problem that won't go away.
Pull the valve cover, remove the rocker arm assembly, and see if you have play in the intake valves: mine were bad enough that you could see the play in the guide.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
