Posted by Edpap on May 10, 2008 at 05:05:28 from (74.33.250.117):
In Reply to: 1066 diesel timeing posted by wildchild55719 on May 09, 2008 at 22:53:02:
Hello, If you just changed out the pump and won't start. set the fly wheel to 18 deg. then remove the timming gear from the pump and rotate the pump one turn or 360 deg and install the gear tourque the bolts to 30lbs and start it. that is a common problem in fact i think the IT manual will tell you do this. Good luck Ed
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
