Something like this happened to my M a couple months ago . It's all been rebuilt now . What happened was the pilot bearing failed and a roller fell out and got jammed into the teeth of the constant mesh gear and locked up the counter shaft to the input shaft . The main shaft would still turn so it was able to be towed in neutral . I'm not sure how the 450 tranny is put together but if it's similar to the M's then you might want to look inside to see what's up . It seems to me that if it was stuck in two gears it wouldn't move no matter what position the clutch was in . If you were able to move it with the clutch disengaged then it's not the gears . If it's like the M then the main shaft turns with the differential , the main shaft has all the sliding gears on it , with it in two gears you get no movement of the differential . That's if it's built like an M . Somebody will enlighten me and you about that . So , if it would only move with the clutch in you have a problem someplace else . Can't help with that . Good luck ! ...Randy
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
