Re: ihc 400 ipto brake band adjustment
Posted by pete 23 on March 07, 2009 at 17:25:09 from (173.87.1.12):
In Reply to: ihc 400 ipto brake band adjustment posted by cob_crusher on March 07, 2009 at 15:37:03:
You can do a proper adjustment procedure following the book or just turn the adjustment screw nearest the tractor in until you have about the width of the pawl tension when engaged. . The marks they are talking about are just so you put the pawl half way between disengaged and engaged, turn in both screws until snugged down, and then back off, I think it is 1 1/2 turns. Should be able to turn shaft with a short punch through hole in shaft when it is in middle position. ( screws are under the little cap on top and probably rusted) pretty cut and dried.
