Float may be bad and have a hole in it. Or it could be sticking either will cause that problem. Or you may not have the float set correctly. Alos if the new needle is a rubber tipped one you may need to set it in the seat for it to seal as it should. To set it you open the carb., remove the float. Drop the needle into the seat and tap it a couple times with something that will fit in that area. Also the seat has to be good and tight or it can leak past it and cause that problem
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
