Re: 806 hydraulic
Posted by shoes on May 10, 2008 at 17:05:56 from (69.77.237.33):
In Reply to: 806 hydraulic posted by Elvin Winans on May 08, 2008 at 08:33:52:
Check the oring on the hyd filter cover, I just had one that was cut. When it is cut, it takes forever to prime the pumps after a filter change, and also will affect hitch and steering operation. Good Luck
