Re: Farmall H with IH no 30 Loader
Posted by JT on May 10, 2008 at 18:08:58 from (99.203.194.12):
In Reply to: Farmall H with IH no 30 Loader posted by Andy Motteberg on May 09, 2008 at 20:54:58:
Andy,
According to the book, you put loader and piping on, fill resorvoir, raise loader about 5 feet off the ground, the refill resorvoir, then you should be good to go. By doing this way, you fill both cylinders, because, as others have said, the front of the cylinders are the oil resoroir.
Jim
