Re: Sure ain't ah going to make a habbit
Posted by cadet trooper on May 10, 2008 at 19:02:52 from (68.253.225.218):
In Reply to: Sure ain't ah going to make a habbit posted by the tractor vet on May 10, 2008 at 14:27:57:
Oh so you got a taste of metric wiring? Good luck with that I worked for the Japanese for ten years and still have problems switching back and forth big problems with quick connectors. I'm redoing a Jap subcompact and having similar problems but electrons are electrons no matter where in the world. A couple rule of thumbs .0394" is a millimeter and roughly 25 millimeters is an inch. but you probably knew that. Good Luck CT
