Re: Oil pressure
Posted by Janicholson on May 11, 2008 at 18:15:58 from (64.83.197.92):
In Reply to: Oil pressure posted by mkirsch on May 11, 2008 at 18:10:35:
Two things easy. thin oil, and heat.
if temp is good, 15 40 oil can make more pressure.
if hot, fix the cooling system.
the cubs's oil pump is built into the block, and is not friendly to get to. worn bearings, or a scored / worn pump are also possible. Good luck, JimN
