Re: Oil pressure
Posted by Andrew Z on May 11, 2008 at 18:19:52 from (12.76.130.60):
In Reply to: Oil pressure posted by mkirsch on May 11, 2008 at 18:10:35:
Worn bearings on the rods and mains. and or oil pump is worn. If your running a light oil such as 10w-30 then try strait 40 or `15w -40 that will get you a few pounds there, but this would only be a band aid though. There real easy to work though and parts are relatively cheap.
Andrew
