Re: A cylinder 2 and 3 not firing
Posted by 1fortyfanatic on May 11, 2008 at 22:41:21 from (4.228.9.155):
In Reply to: Re: A cylinder 2 and 3 not firing posted by 658834 on May 11, 2008 at 20:18:16:
Teddy, I re-state that it is unlikely that a bad gasket could lead to "screwy" compression readings, but even you have admitted, that it is possible. To quote you in one of your earlier posts:
"The only thing running without manifolds will do is eventually burn the valves due to the heat not being carried away from them through the manifold."
Then in this last post, you state...."If the valves are not closing that either means you have poorly adjusted tappet gaps, burnt valves or....."
So, I hope you understand that my point was, as you have already stated, that A can lead to B.
Now with that said, while extremely enjoyable, none of this discussion between you and I is really of any help to francois in his original post. But it has kept me on my toes tonight :D
Dave
