Posted by georgeky on May 12, 2008 at 10:22:32 from (64.12.116.73):
In Reply to: Oil pressure posted by mkirsch on May 11, 2008 at 18:10:35:
I wouldn't get to fired up about an overhaul yet. Lots of Farmalls do that very same thing. I run 5 or 6 here, and they all drop off quite a bit after running to operating temps, and orking hard. A couple of them even have brand new rebuilds on them. Gauges will also vary quite a bit sometimes. I would hook another gauge to it, and see what that shows. I ran my 1949 C for 21 years, and it never held over 5-7 PSI when working hard. Would show 45 or better cold, but went right on down with heat. I could pull the valve cover, and oil was flying everywhere, so I know it was oiling plenty.
There is a lot of deception to oil pressure gauges to start with. I hear people say mine holds 60 or 70 pounds all the time. It would blow every seal in the engine out if that was true. Had a wise old IH mechanic tell me a hundred times that if it is holding 7 pounds that is plenty. Now I know I will be flogged for this, but most the time it isn't a big deal. You should however make sure you are getting oil where it needs to go, and go from there.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
