Farmall C hunts
Posted by takeabet on May 12, 2008 at 15:18:23 from (12.145.58.195):
I am working on a C that has a fresh rebuild and a new Zenith carb that was rejetted because it ran lean.
We put it on a dyno to break it in and it makes a solid 25hp at 600 pto speed but when you load it down to the 540 speed it starts to surg. The plugs are burning brown in color so the fuel is ok. What else could be causing this problem? Could it be the coil? Oh the same Carb makes 32hp on another C with out touching a thing.
Thanks!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
