Posted by Janicholson on May 12, 2008 at 18:47:21 from (64.83.197.92):
In Reply to: Non-detergent oil posted by Ernie O on May 12, 2008 at 18:35:43:
buy an oil pan gasket. Remove pan (keep track of the bolts, end bolts are longer) if ut looks spiffy and clean, clean the pan and put a batch of sacrificial cheep oil. run it for 5 hours or so, then change to good oil and filter. If sludged, clean and do the same to the valve area with kero, and the pan off. JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
