Re: 1086 jumping
Posted by Ted in NE on May 12, 2008 at 19:47:52 from (74.85.105.165):
In Reply to: 1086 jumping posted by d2dpaint on May 12, 2008 at 08:18:44:
Check the bracket that mounts the clutch linkage. The early ones were mounted to the clutch houseing. Made the cab move up & down when you used the clutch. First improvement pkg. would break & make clutch jumpy also. Last up date pkg. worked fine. No update or crack in old bracket is the most common cause of a jumpy clutch on the 86 series.
