Letter series never had solenoids or starter relays as OEM. (Key type starting required the change) All Letter series had switches to engage the elecrticity to the starter motor (which had an inertia spiral drive system to put the pinion into the ring gear) A solenoid is a device that is a linear, or partial arc electrical to mechanical device (like a crane magnet picking up steel) Thus the solenoid, that is also correctly called a relay, shaped like an oversized film canister, is an electrical switch powered by a solenoid internally. A solenoid with mechanical connection to the starter pinion, and an electrical switch is a dual purpose solenoid moving both the switch contacts, and mechanical linkage to the starter drive. Ford starters from the early sisties were interesting in that they used the film can looking electrical relay to power the sterter, and a movable pole piece in the windings that slapped into place when the starter got battery volts to push the drive into place through linkage. Purists are able to call them anything but a potato, and be OK with me. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
