Re: 1944 H Starting Running Problems
Posted by CNKS on May 13, 2008 at 17:17:38 from (216.144.104.128):
In Reply to: 1944 H Starting Running Problems posted by Andy Motteberg on May 13, 2008 at 17:11:11:
Make sure the intake manifold does not leak. You have a lean condition. I usually soak carbs overnight. When you squirt compressed air in it, it has to come out somewhere. If you can't find the exit for the air, you have a plugged passage.
