Re: 1944 H Starting Running Problems
Posted by Janicholson on May 13, 2008 at 17:25:05 from (64.83.197.92):
In Reply to: 1944 H Starting Running Problems posted by Andy Motteberg on May 13, 2008 at 17:11:11:
I agree with CNKS, Fuel is the issue. Make sure there are no manifold leaks, inside or outside (meaning into exhaust ports, or to air on the outside) Is the screen in the carb inlet fitting clean?. If different carbs do the same thing, it is either after the carb, or before it!! JimN
