Re: Re: Leaking coupler?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Les Repair on March 10, 2000 at 17:01:08 from (206.28.174.136):
In Reply to: Re: Leaking coupler? posted by RB on March 10, 2000 at 16:21:47:
You don't have to drop the pump. Remove the two large cotter pins and slide the sleeves together to remove the coupler shaft. The slotted coupling comming from the transmission is threaded to the transmission shaft. it is normal right hand threads. By turning the engine to get the coupler in the right position you can put a bar through the slots to get it loose.
Post A Followup
: Re: Re: Re: Leaking coupler?
