Re: 1944 H Starting Running Problems
Posted by James Williams on May 13, 2008 at 18:01:01 from (74.46.216.57):
In Reply to: 1944 H Starting Running Problems posted by Andy Motteberg on May 13, 2008 at 17:11:11:
Andy it sounds like to me low compression,rings might be stuck.You probally need new rings and hone your sleves,Maybe valves arent seating.Do a compression check.Lubericate your cylinders,than try starting it
jimmy
