Re: Trying to get a 330U running
Posted by Bringselpup on May 13, 2008 at 19:02:46 from (216.227.12.220):
In Reply to: Re: Trying to get a 330U running posted by Janicholson on May 13, 2008 at 17:33:33:
You bet it feels good!
I used the factory gap on the plugs (autolite 3116) can anyone tell me what the spec calls for so I can be sure they are right?
I put new gaskets in the carb and a new needle valve seat. I reused the needle valve that was in the carb because the kit from the dealer had a needle valve that wasn't anything like the one I found inside. It seems to work. What things can I do to fine tune the carb any?
The oil looks good in the engine but I will feel better changing it. Do i use straight 30w as I am seeing suggested in other posts?
