Re: Farmall 100 float height
Posted by CNKS on May 13, 2008 at 19:32:30 from (216.144.104.128):
In Reply to: Farmall 100 float height posted by Daniel H. on May 13, 2008 at 19:12:49:
The A is 1 5/32 from the top (bottom) of the float to the gasket measured upside down. I imagine the 100/Super A is the same. A good kit will have that spec with it. Fuel level is 15/32-17/32 measured from the gasket. I don't know if that is a 67x7 or a 161x7, probably both the same. I do not consider that a highly critical measurement. Basically the float should be in a horizontal position.
