Re: 1944 H Starting Running Problems
Posted by BIG BORE 20 on May 13, 2008 at 20:34:04 from (12.192.31.234):
In Reply to: 1944 H Starting Running Problems posted by Andy Motteberg on May 13, 2008 at 17:11:11:
Andy,
I bought an f-20 about 30 years ago that did just about what your H is doing. It turned out to be the manifold had a rusted through between the intake and the exhaust inside the manifold below the exhaust pipe outlet. This was hard to find, it drove me nuts for a while. I did all the things you have done before I found the hole. After pulling the manifold off I could look into the intake and see clear through it and out the exhaust pipe. Hope this helps.
