Pull the gas line at the carburetor and remove that fitting where the gas line was connected and check for a clogged screen behind that fitting. You should have a full stream of gas from the tank too. Catch the gas in a clean container. You will probably need to close the shutoff valve if there's much gas in the tank. Since you have good suction at the throat of the carburetor you have blockage of fuel. Hal
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
