Re: The right Hyd. Fluid, for Farmall 340
Posted by MN Mike on May 14, 2008 at 05:43:16 from (216.77.154.39):
In Reply to: The right Hyd. Fluid, for Farmall 340 posted by M inMo on May 13, 2008 at 17:01:22:
As the other guys implied, the 340 takes HyTran instead of straight hydaulic fluid. I run an off brand in mine that meets Case IH specs
