Posted by Janicholson on May 14, 2008 at 06:22:20 from (199.17.6.122):
In Reply to: RPM to PTO speed posted by John in pennsylvania on May 14, 2008 at 04:19:49:
The issue is not critical. The full load speed of the engine is the point at which the engine is making its rated HP and it is usuallu about 80% or so of full throttle no load. This means that at no load with the throttle wide open (hurts nothing) the engine will turn about 20% faster than rated PTO speed. I know of no reason to worry about it. the slight overspeed will not harm any equipment. If it is a light load, and throttling down is needed to conserve fuel, that 80% might be close. It is not a good idea to lug an engine below about 75% of max idle. this produces less actual HP, and overloads bearings and drive train. JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
