If whoever rebuilt it knew what he was doing, those initial adjustments are already done according to factory specs.
Do you have a good flow of fuel from the tank? Do you by any chance have one of those in-line fuel filters installed? If so, get rid of it.
There are only two adjustments which could effect it. The idle air adjustment screw should be gently turned in until it seats, and then turned 1 1/2 turns out. The high speed idle, or load adjustment screw, should gently turned in until it seats, and then turned a full three turns out.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
