Re: Fuel Bowl
Posted by Red Mist on May 14, 2008 at 14:03:24 from (208.61.169.68):
In Reply to: Fuel Bowl posted by Gale Roberts on May 14, 2008 at 12:07:26:
Gale Roberts said: (quoted from post at 12:07:26 05/14/08) If you put a new Gasket in the fuel filter and did not get gas when you opened the filter shut-off valve and then blew back through the gas line into the tank then you must have some dirt in the gas tank that you dislodged when you blew back through the line. If that is the case then it will probably find it's way back and cause blockage again.........Gale
Not necessarily. What Rustyfarmall says is exactly right. Once you remove the glass bowl and reinstall, it will air-lock. Open the fuel valve, fire it up, and it will self correct and all will be fine - in 99% of the cases. mike
