Farmall 140 Gears
Posted by Vacherie on May 14, 2008 at 18:45:09 from (205.188.116.73):
On a recently purchased 140 all the gears work except first. As long as I hold my hand on the shift lever it works. When I remove my hand the
transmission goes to neutral. What do I need to to correct this problem? The guy I bought it from said he tried to pull start it in first gear..
