Re: Positive or Negative ground.
Posted by Andy Motteberg on May 14, 2008 at 22:42:54 from (4.143.217.30):
In Reply to: Positive or Negative ground. posted by Rexalot on May 14, 2008 at 21:54:40:
If your C is wired correctly for negative ground, your battery should not be draining down. Make sure it is wired correctly and all wiring and connectors are in good condition. If you want to convert it back to positive ground like it was when it was new, be sure that all the electrical system wiring is correctly wired. We have a SMTA that drained batteries once and found that there was water in the regulator, that can happen also.
Good luck.
Andy.
