Posted by the tractor vet on May 15, 2008 at 09:39:37 from (76.212.230.0):
In Reply to: Vet... posted by Bob on May 15, 2008 at 08:37:26:
Don't know just the way i do it. Use the CV relays on a lot of tractors . Like on the 06-66 to take the load off the light switch when ya start adding extra lites , i do away with the fuse and add breakers and a CV relay. Started doing that after i had a problem with one 706 i had and on a vary dark night miles away from pick up and NO FLASH LIGHT no lighter stumbling around plowed ground because i blew the fuse . But i did have a couple extra in the tool box on the tractor it was just trying to get to the tool box then trying to put the fuse in by the braille method only to go one round and have them go out again just because i added ONE extra light on the rear . So replaced that fuse and had two left and before i got to the head land one more went . Unpluged the one rear lite shut down the field lites crossed my fingers and headed to the other farm where the truck was at . just as i pulled into the lane that fuse let go . Part of the problem was rust on the hot post of the light switch plus the extra lite . That is when i started usen the CV relays then just used them when we made the change from gen to alt . seems to work ok had no problems So if it ain't broke don't fix it. Plus never knew much about all them fancy diodes .
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
