Re: international 1586
Posted by Steven f/AZ on May 15, 2008 at 14:03:06 from (216.67.213.217):
In Reply to: international 1586 posted by Chris28 on May 14, 2008 at 19:44:32:
If you don't have a lot of blow-by or burning oil, I'd say it's time for a pump rebuild and/or injectors rebuilt.
Problem becomes instead of spraying a mist into the cylinder to be ignited, they "dribble" fuel in and it doesn't ignite well.
I'd have the injectors bench tested, followed by a compression test, and LASTLY go to a pump rebuild if the other two check out. I always start with the simplest/cheapest thing.
