Re: Engine block paint/sealer
Posted by CNKS on May 15, 2008 at 17:26:51 from (216.144.104.128):
In Reply to: Engine block paint/sealer posted by charles todd on May 14, 2008 at 19:59:26:
charles todd said: (quoted from post at 19:59:26 05/14/08) I am curious about this "crankcase sealer". At one time my F504D threw a rod and knocked two holes in the block. These were welded well and some type of sealer was used (seems to be silver), it weeps just enough to annoy me and keep the block oily/dirty, but not enough to call it a leak... I would like to repair this, kinda hard to plan a repaint as is. Help!
Charles
I don't know if you meant they put it on the inside or outside of the block, but sealer is supposed to be used on the inside, from what little I know about it. I doubt if you want to disassemble the engine, but that probably is the only way to fix it. Seems like it should have been welded on the inside, also.
