Re: 1944 Farmall H Running Problem
Posted by Andy Motteberg on May 15, 2008 at 22:40:46 from (4.143.220.250):
In Reply to: Re: 1944 Farmall H Running Problem posted by Andrew Z on May 15, 2008 at 06:21:53:
It seems to have good spark, when you can finally get it started with a hand over the carb throat, it runs for a very short time and shuts off again.
Thanks,
Andy.
