Posted by Hugh Mackay on May 16, 2008 at 02:39:06 from (216.208.58.147):
In Reply to: PTO Shaft Length posted by HAS on May 15, 2008 at 19:20:39:
Has: 50 years ago there was a standard in the industry, distance from end of PTO shaft to drawbar pin hole. It used to be 14", and was quite reliable for mainline manufacturers equipment and center line PTO tractors.
When my dad bought the 130 it came with fast hitch, and we wanted to use couple of pto implements, thus we fabricated a drawbar to be same specs behind pto as H or 300. One item was the IH 7' semi-mounted sickle mower, and that one is easy as mower was designed for H or 300 on 72" wheel tread. You put a 130 on 56" wheel tread and mower PTO is in direct line with tractor PTO.
Next was a 130 bushel manure spreader, bit more difficult. PTO is offset 8" to left of tractor centerline. Pulling that big spreader we knew we couldn't put drawbar hitch point directly behind the PTO. The little tractor was going to be loaded to it's limit and then some with 130 bushel spreader. We split the difference and placed drawbar 4" offset left from center line if tractor, yet still 4" offset right from centerline of PTO. We then very carefully with PTO not running, put tractor and manure spreader through every possible manuver we could think of, with a second guy on behind to watch PTO drive line. It was a bit of trial and error, however we adjusted the drawbar hole to work with standard PTO implements. I have baled hay with 130 and NH S-69 baler, not a lot, but it did work for that.
About the only thing I can suggest is come as close to the 14" measure as possible, and as close to centerline with PTO, then very carefully put it through it's paces (PTO out of gear) with someone on behind watching.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
