Re: 1006 TA - High Side Slip
Posted by Kevin Meier on May 16, 2008 at 15:23:13 from (64.71.85.247):
In Reply to: 1006 TA - High Side Slip posted by Lance_MF_180 on May 16, 2008 at 07:44:01:
Does it slip when the brakes are applied or steering is being used? You may have a bad pump, sump plug leaking, or plugged filter. You should make sure your adjustments are correct first and put a set of pressure gauges on to see if that is correct. When a t/a slips in direct drive it automatically is picked up by the sprag on the ta side and will cause more problems.
