800 cyclo air corn planter not planting
Posted by Foege on May 16, 2008 at 19:42:31 from (12.213.112.59):
My planter is not planting ??? Everything seems to work ,the drum turns raises lowers ,markers ,have a new 1000 rpm pto pump .It appaers that I am not getting enough air pressure to the drum to hold seads in the dimpple long enough to get to the press off wheels and drop the seed . The seed will travel to the 12 0'clock possition and fall off . I have replaced the flow control valve and have turned it all the way in giving max flow to the orbit motor to turn the fan(blower) .The rubber back seal is in good shape and have taken out a shim to bring it closer to firewall.Have checked oil in pump it is full . It seems that the fan does not put out enough air or I have a major air leak somewhere that I can not find . Have beat my head in all day , any sujestions good or bad may be considered . It is time to plant at least here.
