It is possible but not very likely that you have enough oil pressure to blow the head gasket. While the psi could be very high, the passage is very small, i.e. there is not much force there.
Chances are that there is a defect in the head, the block, the gasket, or sorry to say, the installation, that is causing the gasket to fail.
The last major repair was the head gasket, so that is the first place to look. It won't hurt to have a look at the oil pump, check the pressure relief spring (they get tired usually), clean up the end plate, replace the gasket, etc., but it sounds like the head gasket failed twice in six months. Something is not right higher up in the motor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
