Re: Farmall C over heats...why?
Posted by gene bender on May 17, 2008 at 04:16:46 from (67.55.226.69):
In Reply to: Farmall C over heats...why? posted by Al Hinds on May 16, 2008 at 19:16:58:
What temp is it running when you say hot? With the water pump it should be ok. You mite need to remove the radiator and hook a hose to the bottom outlet and back flush. I would try OLDS method of the vinegar first. You cont need a thermostat as i have instaled pumps on those engines without any problems. There isnt any way to install one as the SCs had a bigger neck for the thermostat and that radiator was taller so wont fit your tractor.
