Re: 460 industrial fixed????
Posted by frkln on May 17, 2008 at 19:32:17 from (75.105.95.41):
In Reply to: Re: 460 industrial fixed???? posted by CNKS on May 17, 2008 at 19:19:07:
thanks for the info. i will have to mess with it in the morning.
the tank and fuel bowl look pretty good. it almost feels like part fuel or part electrical. kinda like when your sprak plug wires on you car get a little moisture on them.
so far the clutch and ta seem to be working good. will have to test it more when i get it running better!
but so far i even put it in fourth and it ran pretty good until it started bogging and running rough!!! we shall see. time will tell.
but thanks again for all the help and advise!!!!
